Bamboo Basket Wall Hanging
Creating a bamboo basket wall hanging can be a unique and creative way to decorate your space.
https://pin.it/nrEnMtd
Here's a simple guide to help you make a bamboo basket wall hanging:
Materials Needed:
  1. Bamboo Strips or Sticks:
    • You can purchase bamboo strips or sticks from a craft store or online. Ensure they are flexible enough to bend into shapes.
  2. Twine or Raffia:
    • Use twine or raffia to bind the bamboo sticks together. This will also add a decorative touch.
  3. Scissors:
    • For cutting bamboo sticks and twine.
  4. Glue or Wire:
    • You may need glue or wire to secure certain parts of the basket, especially if you want to create intricate designs.
  5. Decorative Elements:
    • Consider adding beads, feathers, or other decorative elements to enhance the visual appeal.
Steps:
  1. Prepare Bamboo Strips:
    • Soak the bamboo strips in water for a few hours to make them more flexible. This will make it easier to bend and shape them.
  2. Create the Base:
    • Take a few bamboo strips and bend them into a circular shape to form the base of the basket. Secure the ends together using twine or raffia. This will be the foundation of your wall hanging.
  3. Build the Structure:
    • Add more bamboo strips to create the sides of the basket. Weave them through the base, securing them in place with twine or raffia. You can experiment with different weaving patterns to add interest.
  4. Add Decorative Elements:
    • Incorporate beads, feathers, or other decorative elements into the design. Attach them securely with twine, glue, or wire.
  5. Create a Hanging Mechanism:
    • Attach a loop of twine or raffia to the top of the basket to hang it on the wall. Ensure it's securely fastened so that the wall hanging is stable.
  6. Finishing Touches:
    • Trim any excess twine or bamboo, and make sure all elements are securely attached. You can also add a coat of clear varnish or paint to protect the bamboo and enhance its appearance.
  7. Hang on the Wall:
    • Find a suitable spot on your wall to hang the bamboo basket. Consider its weight and use appropriate hooks or nails to ensure it stays securely in place.
Remember, you can get creative with the design, size, and shape of your bamboo basket wall hanging. Experiment with different weaving techniques and decorative elements to make it uniquely yours.
